In a new kitchen, trying to work out the best way for extraction.(Not sure if this is the most appropriate forum, but I'll try.)
The steel in the ceiling/floor is in the way of any "normal" hood.
I have tried to pull apart some hoods in the sheds, to see if it's possible to do without the top "chimney" section, or to take the outlet pipe from an off centre position (to run vertically up into the void, then left) but always get thrown out.
I could do what I show in the drawing (ducting would be left exposed),but maybe the bright sparks here know of something better, such as a ceiling mounted unit, complete with fan, with an offcentre outlet?
I'll be looking for extraction rates of min 300m3/hr, which rules out most of the flat recirculating type.
I don't want to take the outlet through the wall below the steel mainly because I think this will compromise the structural integrity of the wall.
Any thoughts or suggestions welcomed!
