- Joined
- 25 Aug 2008
- Messages
- 5,776
- Reaction score
- 2,941
- Country
HAve stuck this in several places unless my computer illiteracy has finally found its way out!
Was it from the sump plate cover with the black gasket?? If so the ideal part no is 170899 and the BGC no is E67481. If it was between the hex and the top of the sump with the red high temp mastic seal then its a new hex as its probably a condense blockage coming out the seal(I have had this with water building up and eventually perishing the mastic. The black gaskets on the sump plate cover are usually robust and I have not had to replace one.
Any probs get in touch!
Cheers
David
Cheers
David
