Apologies if this is in teh wrong section.
I'm in an end terrace and a fair amount of noise comes through my fireplace from next door. The walls seem fine but you can hear every word spoken if you put your head close to the fireplace and it's beginiing to annoy me.
I'm not sure on the correct term for the fireplace as it currently is - it's basically just an open brick cavity in which I've got a basket. It's used often in the winter.
I'd like to install/have installed something like this
my question is as follows:
If this is correctly installed with the excess gap behind filled with fire bricks and then vermullicite (sp) - in people's experience will this create a decent block to the sounds coming through?
Also - I'd be interested in hearing any other thoughts on the sound travel.
Many thanks.
Many thanks.
