MY shower just wont get hot, so i think the thermostat has gone. I am going to fit a new shower, the question is how do i find out what kw shower i can put in?
It will depend on the length of cable as well as the power rating of the shower, but you will be looking for 10mm cable at least, as well as upgrading the fuse/mcb for the new circuit and possibly any isolating pull switch
I dont think anybody is doubting that you could do it, just that you need to have the work certified afterwards if doing it yourself (which will be hard to find a sparky willing to do that) or get a sparky to do the install.
The cable size depends on a few things, the length of the run, how it will be fixed to name a few. As somebody mentioned your fuse box may need upgrading with the correct fuse/MCB.
As on the electrics forum on this site for more advice.
