Fitting pressure relief valve
31 Dec 2003
I think the 3 bar pressure relief valve on my system is leaking. Do I have to drain the system down to fit a new one?
Can't find a leak.
I tested the PRV and re-filled the system then shortly afterwards the pressure rose to just over 3 bar from 1.5 bar, the PRV activated and I saw water in the tundish. So maybe the prroblem is in the boiler not leaking pipework.
Am going to check the pressure vessel tomorrow and then call a central heating engineer.
Thanks for your contributions.
Regards
How do you test them?
Pressure Rose to over 3 bar and the prv let go, seems to be working to me.
