Fitting urinals
4 Apr 2010
Humberside
How hard of a job is fitting urinals with exposed pipework? Does the pipework come to length then you have a diagram to fit it to?
and pipe work is exposed.
So you said in the OP. I must pay better attention.
How is the cistern to be filled; petcock, Cistermiser, infra-red device?
Simple job. So much so that I'd even give it a go. :wink:
Is fillied by a pet cock.
Does the kit come with a diagram then stating what height and what distances the urinals and cistern should be apart to allow the pipework to fit?
all the ones i fitted had chrome compression and you would cut the pipes to the size you wanted.
