One of the palm squeeze ones, not an office desk paper joining one.
Or a leccy one can be had quite cheap. If using foil backed plasterboard, no need for VB.
If using the insulated PB as per my other reply then also no need.
much cheaper and easier to use a plastic sheet rather than having to slice of all the excess bubbling above the line of battens so you can get pb to screw down flat
What's the VP you keep mentioning and are you sayimg your battens are EXACTLTY vertical and you then cut your panels EXACTLY square so there are no gaps at all ?
