- Joined
- 17 May 2012
- Messages
- 11,233
- Reaction score
- 961
- Country
OK, so I ordered about 10m square 50mm insulation board from building merchant to insulate between joists. They called to say due to national shortage (discussed in another thread the other week!) that they had none, but would send out double the 25mm instead.
But, rather than keep their word, they just sent out equal value of 25mm insulation, which does not cover the same area! (50mm was 18 boards 0.45x1.2 = 9.72m, 24mm is 4 boards 1.2x2.4=11.52m, but half the thickness, for the same price!).
Advantage of the local building merchant is its free delivery to my door (not roadside) for orders over £30, so I don't want to cause trouble ....
I was thinking, so I've just ordered 2 packs of 50mm Knauf Earthwool Dritherm 35/37 Cavity Insulation instead, that will cover the whole area.
Now, do I:
Now, do I:
- Just put the earthwool in and save the 25mm board for the walls, that need doing too.
- Put 25mm board on battens and then lay the 50mm on top for better insulation
- do a mix of 50mm solid using 2 25mm boards, and 50mm earthwool.
- Give up and watch more Walking Dead.
