ford fiesta ignition problems
9 Feb 2009
Kent
Hi everyone ive got a 1998 fiesta 1.3 that has no spark at the spark plugs. I have fitted new plugs, leads and coil pack. I have had the crankshaft and cam shaft sensors checked all ok. I have 2 live feeds at the coil when ignition is on and engine turns over fine just no sparks, any advice/help greatly appreciated cheers ian
sounds like you have the most common problems sorted there,if you have a feed at the coils then id be looking at the how the negative is being switched,possibly by the ecu?
could the immobiliser be at fault?
Cheers mate do you have any idea how to check what you have mentioned? thanks ian
