Gas Hob pressure drop when boiler fires up
16 Nov 2011
Hampshire
Recently installed a gas hob and the gas pressure drops right down when my combi boiler kicks in. When all 5 rings are on and I turn the hot kitchen tap on, they all reduce right down and sometimes go out completely.
The only gas appliances I have is a condenser combi boiler and a 5 ring gas hob. The meter, boiler and hob are all in a line (less than 4 metres between them all) with only a couple of elbows and two tees. All 22mm pipework (except for where it reduces to 15mm for the hob)
I have done the flow calculations (using pipe length, kw) and it shows the pipework diameter / lengths I have are more than adequate to be able to supply the boiler and hob.
What else could be causing this?
Does it happen at all times of the day?
Could have a dodgy regulator, as said, National Grid will sort it for you.
