Hi, I have the above boiler, ep2002 programmer, three port valve, three wire room stat, tank stat, and pump. I have had to rewire the wiring centre as the spaghetti and chocolate block nightmare that was housed in a single socket enclosure, was pulled out of the wall by accident (ironing board). I have assumed it's a Y system (please correct me if I'm wrong,) I can't make the system run however as I can't figure out what I should be doing with the switched live and pumped live connected to the boiler. Please can someone with more electrical nous than me, send me in the right direction. Thanks.
