glow worm 55ff cutting out
25 Feb 2005
hi, glow worm fuelsaver 55ff runs for about 4minutes starts to heat up water and rads but then switches off for about 6 minutes then repeats cycle obviously not giving it time to heat rads. any suggestions for a cure would be appriciated.
Does it stay on for same length of time wether the stat is on max or low ie is it actually cutting off on the stat or is something else cutting it off
When it has just gone just gone out see if boiler stat is clickin still if it is then its not a case of the boiler overheating.
Iwould then be looking at the gas valve solenoid breaking down under use.
If it was the motorised valve both HW /CH would not be affected.
If it was the pump then you would get a banging noise with the heat in the boiler
