Can anyone help
my glowworm compact 80e has no hot water the central heating works fine. A few weeks ago I adjusted the pressure as it was to low it went to high but then i got it back down to normal. This caused the valve at the other end of the loop valve to leak think this was because of the high pressure. Tightened this valve and the leak stopped. The water light does not come on. for a while if you ran the tap at full it eventually went hot but now it just stays cold.
Appreciate any help
Appreciate any help
