Can anybody here tell me what is causing the following problem?
My Glow Worm Ultimate 60ff boiler fires up in the morning but within 5 minutes, it trips. The reset button can be pushed in after a few minutes and usually, everything is then ok. (SOMETIMES, after the reset, it trips again; but after the 2nd reset, the system works well.)
ONCE IT IS WORKING, it will run perfectly for as long as it is left on. (In fact, I left it on for 4 days to determine if it was an overheating problem. No tripping and no resets needed). ONLY AFTER THE WATER HAS COOLED (i.e, overnight) does the problem return.
Any ideas?
Thanks in advance.
Tim
Any ideas?
Thanks in advance.
Tim
