- Joined
- 14 Mar 2018
- Messages
- 2
- Reaction score
- 0
- Country
Hi folks, have a grant 26e outside oil burner.
Currently the heating is ok but no hot water runs but is cold. Fires up on water, flow switch is ok, pump ok, demand light and flow light comes on as it should. just noticed If I leave it on hot water the pressure creeps up to 2.5 bar ( from 1.5 on heating) and it locks out, but it will run all day on heating. If have taken the TMV valve off and cleaned it however the hot pipe from the heat exchanger going into the TMV is cold and the heat exchanger is also cold. Given It locks out when trying to heat the water is this pointing towards a duff or blocked heat exchanger, Any help in the right direction would be very much appreciated.
Cheers
Steve
Cheers
Steve
