Hi all
I've been having some problems with the boiler over the last while and I'm looking for some more advice.
I've been having pressure problems for a while now, http://www.diynot.com/forums/plumbing/leaking-halstead-platinum.331823/, and as in the other post the pressure was still dropping. I found a leaking gate valve for the system drain under the floor beneath the boiler and replaced it.
I do still have a PRV that is dripping very slowly and I'll need to replace.
I checked the pressure vessel for any evidence of water in the unit, only air came out, and recharged it to 1 bar.
I refilled the boiler to 1 bar and fired it up. The pressure climbed quickly to 3 bar so I turned the stat down and then boiler off.
I drained the system again and charged the pressure vessel to 1.5 bar and refilled the system to 1 bar. When I fired it up the pressure rose again to 3 bar.
Now, the radiators are getting hot quickly and there is no air in them.
I know the AAV is working as I can hear it when I drain and refill.
Why is my pressure climbing to 3 bar? I don't want to charge the PV to more than 1.5 bar as the manual doesn't tell me what pressure to set.
I am stumped with this and need some advice.
Hallstead Platinum boiler in a bungalow with 5 small single rads and 2 large double rads.
