Hi, wonder if anyone can give advice, every so often the overheat lockout light comes on and won't re-set on the button on the control panel. If I take the front main case off and go to the top left hand side of the boiler, there is a re-set button, just click this down and it's all ok again. Should the re-set button on the control panel activate the one inside the casing and if so, which one needs replacing.
Just a bit of back-ground on this boiler. Replacements so far, PCB, divertor valve diaphram, pressure release valve. The system has been bled, no air in it.
Many Thanks
Acker
Many Thanks
Acker
