Heat only SE to HE system boiler.
One for the combustion chamber forum dude.
But no, you are not allowed to use two separate power feeds.
In theory though, if the gas supply is adequate for your current boiler, then it will for the new.
Although there are some manufacturer's that stipulate a minimum pipe diameter regardless of the capacity of the supply.
Thanks Dan, I hadn't realised I was still in here and not in CC.
Reposted accordingly.
