Heat resistant foil tape for cooker stud wall
16 Oct 2008
Wiltshire
I originally had this as a topic in Applicances but got no response - perhaps someone here might like to comment?
I'm installling a new kitchen (in a ridiculously small & non square space) and have built & installed a small 600mm studwall across one of the corners against which the cooker/hood can be placed/mounted.
This stud wall doesn't go all the way from ceiling to floor but stops around 3 inches below the cooker hotplate level & is supported by a 2" x 2" piece of timber that's mounted on a couple of battens on either side wall.
Now, I want to insulate this supporting timber and was thinking the easiest way might well be to just use a heat resistant aluminium foil tape.
Anybody see any issues with this or can recommend anything more suitable?
Cheers,
Andy B
Im not sure i fully understand what your trying to do. Cladding the timber with plasterbaord will provide 30 min resistance. If its that close that its casusing burn marks. Then you are breaching manufacterer instructions.
Normal hotplate clearance gas is like 50mm. and nothing within 400m ( dont quote me) above.
