Hi Guys,
I have a Potterton heating system in my house with 9 radiators (without TRV’s) scattered around the house.
All of a sudden last week the CH completely stopped working and the HW was scalding hot. The CH pump was working ok and I could feel the hot water circulating through it but I just could not work out why the radiators were not getting hot. I then suspected an airlock I the system. So over the weekend I turned off the heating system, and the water feed to the F&E tank in the loft. I then turned on the valves on the radiators fully open. I then connected a pipe from the outside tap to the bottom of the lowest radiator in the house and got the missus to turn the water tap on and off while I watched the F&E tank in the loft. I did not notice any air bubbles appearing in the F&E tank…strange I thought.
Anyway, I then turned the system back on thinking that was the end of the problem. I made sure the pump was running and hot water was circulating through it as before, everything seemed fine except….the radiators were not getting hot!! Anyway, after kicking the cat,
I sat and thought and at the time did not think to check the motorised valve. It is a MSV322 (ACT322 actuator) 3 port valve and the neon lamps were on as normal. I then took the ACT322 actuator off the valve unit and turned the valve with a pair of pliers and…..the radiators started warming up!!!
I have discovered that the ACT322 actuator has finally seen better days. I have left the actuator hanging off with the valve in the mid position until I get the actuator sorted.
My question is to the more expert of you all…
Is it possible to fix this actuator? If it’s the motor inside the actuator, where can I get a new motor? If it’s the components, are they easy to get and replace?
Cheers all.
Cheers all.
