Heatlin S24 compact boiler
21 Nov 2009
Lancashire
Hi, is any one can help with the faut for the above make & model boiler's, flashing one of LED thats mean "check Air pressure switch", the trouble before this fault started after taking off one of the radiator in the bath room during the refurbishment & boiler started giving trouble intermittently, and by the tabbing on the main PCB it start working and it was working perfectly for more then a week & now its showing this fault.
I wander if any one had an experience and can advise me wether its worth spending time and money or not' well its easy to say NO' but may be some help can save some thing. Thanks indeed.
"Check APS" is a job for RGI, did you check the system pressure after refitting rad?
Thanks, some one had a look and daignosed PCB faulty, geting replacement.
If tapping the PCB caused it to start working then it MIGHT well be a fault with the PCB.
However, that would be a fairly unusual problem with that model. I would say more likely to be something else or a faulty connector.
Many installers say its the PCB when they dont really know whats wrong.
Please let us know what the outcome is.
Tony
Thanks Tony, I will monitor what they are doing and leave feedback for the forum.
