Help!! Glow worm boiler.
15 Sep 2005
Hi.
Hope someone can tell me what i have done wrong or missing.
I can only get the hot water to very luke warm.
I installed a new rad. for somone. Pipe work was already there, so it was just a matter or draining the system and installing pipe work and Rad.
I turned off boiler. drained system. After work. I filled systen back. Bleed all rads. Made sure both air vents for central heating was bleed. Checked that there was no air in the heater pump.
Turned all back on. Bleed again.
Rads are fine. Its just i cant get the hot water to warm. The glow worm boiler is alight and burning quite well. Once on. I managed to bleed some more air out the system but cant get it hot.
As someone got a tips.
thanks
tony
How can it be the stat.
Would it effected it when the water was drained out.
is there a motorised valve in the system (silver box with pipes coming out).
Is there a manual bleed point near the side of the copper cylinder
Hi.
There is a manual bleed point. There is two. Bleed them and its gone from cold to luke warm.
Its strange as all the pipes coming from the tank and the boiler are very hot. But they are not feeding going to the taps.
Hi.
Anyone help. Please.
