In some serious need of help with my cold water tank in the loft. My overflow outside is nearly always streaming with water. I got in the loft and it was full up to the overflow (obviously!) After releasing hot water from downstairs it emptied down to the buoy limit which seems to be working fine as i waited in the loft until it filled up and shut off as the buoy should have done. At first i thought it had solved the problem until two weeks later and one hell of a soaked wall that it hadn't. Again it was at a high level but when i put my hand in to see if the buoy had filled up with water, the water was really hot? Unexpected for a 'cold' water tank. After releasing all of the water again i stayed in the loft for a good half an hour and it seems as though water is coming back up the same pipe as it goes down to the boiler! Hence maybe the water being really hot in a cold water tank.
Please could someone help if they have had similar problems.
Regards.
Regards.
