Hi all,
I hope that you kind people can help or offer advice with this problem.
I have a gravity fed water/heating system with a glow warm boiler, room thermostat and a sunvic three port(?) motorised valve, danfoss CP715 programmer, danfoss type AT tank thermostat and a wilo gold 60 pump. I have a total of 13 rads over two floors with 11 of them fitted with thermostat valves. ( I hope I got all of that right!)
My problem is that the rads get hot whenever the water is on even though the rads are turned off at the programmer.
I thought that it might be the motorised valve stuck open so I took it off and watched it when turning on the programmer to the three positions of , both, water and then only heating. It appeared to work ok so I also checked the actual valve on the pipework and that seemed ok as I was able to turn it by hand. I also notice that the loft central heating tank is occasionally dripping from the overflow and it seems that water is being pushed up into the header tank. I'mstuck so any advice appreciated. thanks, Rob
