- Joined
- 23 May 2025
- Messages
- 6
- Reaction score
- 2
- Country
I have a Hormann powered up and over double garage door - single section - that has worked for years and years with no issues. Now it stalls just on opening - the door moves a couple of cm then stops. Pressing the remote button again and it closes as it should. If you encourage the door to open by pulling it a bit as it opens, then the door will go all the way. Then continues to operate normally until you leave it for a few minutes and then it repeats its refusal. I have lubricated the hinge points, and tried tied tightening the tension springs a little to give it a bit more of a pull (they are 26 years old, so probably a little bit tired).
Thoughts? I was thinking in hot weather the springs expand a bit and lose tension slightly - maybe enough to stall the motor. But I've tensioned them a bit more and that hasn't really helped. I find it odd that it works when you're looking at it, but go away and come back and it doesn't work!
Any ideas about what to try next?
