New to the forums so please be kind...
I have a small problem with my hot water. The boiler is heating water fine and the pump is pumping this round the radiators with no issue - and gets very hot - but hot water supply remains unheated.
I have an old style vented storage cylinder with built in cold water/expansion tank at the top (circa 1980). Recently I drained the system to clean it but now everything is back in place my hot water isn't hot.
The water is obviously flowing through the tank to the hot tap and being topped up via the mains supply but is not being heated internally inside the cylinder.
One thing I have noticed is that either the inlet (or outlet-not sure) of the heating coil which connects via the pump to the boiler is cold when it gets nearer to the tank but progressively hotter as gets to the pump and motorised valve. It's almost as if the coiled pipe (not sure of the name) that passes in and out of the cylinder is blocked in some way - or at least the hot water from the boiler is being stopped from flowing freely through the cylinder.
Any ideas would be greatly appreciated.
