Hot Water Pressure to the pump good - after bad
27 Jan 2012
Liverpool
Please help!
My shower after two years started to run cold with very little hot water coming out.
I had a salamader CT75 and worked fine although was very noisy over time. The water feed to the pump (Tank Fed) was good.
On the advise of Salamader, I took the shower unit off and left the two pipes just popping out the wall to test. With the pump off, the feed was still good on hot and cold (Slightly better with the cold). When the pump was switch on, the hot water actually went worse!
I bought a brand new pump as previous believing that was the problem however, the problem is just the same.
Any ideas anyone????
