Hi All, this is my first post, so forgive me if I don't get the protocol quite right...
I'm repairing a Vaillant Turbomax Plus 824e for a client and have come across a problem I've not encountered before.
The boiler was unused for a long period of time and had a couple of standard problems that I resolved (Diverter valve needed changing and AquaSensor had to be cleaned as it wasn't detecting DHW flow properly).
There now seems to be a further problem with the domestic hot water (CH is fine):
When the DHW is run in any circumstances (CH on or off, Warmstart on or off, etc) the temperature fluctuates periodically by around 25C as:
- the burner ignites up,
- gas flow increases until the flow temperature peaks (e.g. 85C)
- then the burner turns off
- boiler waits a few seconds until flow temp reduces (e.g. 60C)
- then the boiler ignites and the cycle starts up again.
The whole cycle takes about 30 seconds.
It doesn't make a difference what the set point for the DHW is on the facia controller.
I can't work out what is happening. There is no fault code and all the diagnostic codes seem to be fine.
The worst thing is that before cleaning the AquaSensor I don't think the problem was there! (Although I may have just missed it).
Does anyone have any tips on what the problem could be and how to resolve this?
Thanks in advance.
Katie
(London)
Thanks in advance.
Katie
(London)
