Hotpoint WD420
27 Dec 2011
Surrey
Hi can anyone help. I have a hotpoint aquarius WD420. I have an error message which is f05 lights 2&4, which I believe means that the pressure switch is stuck on full. Can anyone tell me how I remedy this. I have taken the top off, removed the pressure switch and blown down the tube which comes from the bottom of the pressure switch (came across this suggestion on a website) this has not remedied the problem. Should I just replace the pressure switch or could the problem be elsewhere (filter? pressure chamber? again came across this suggestion on a website but it was suggested for a F04 error, pressure switch stuck on empty). Thanks. Paul
It means the filter is blocked. Remove the rear white cover and look for the big black cup. That's the filter.
Make sure filter is clean and pressure chamber ,if no different could be faulty pressure switch ..but i reckon it will be a blockage some where.
