when spinning, the machine sounds as though its going to fall apart. only about three years old. the noise is worse when on high spped spin. no problem we can hear when washing. it also will not stay put and moves a few inches after a few washes.
thanks for the prompt reply. if this is the case and they are a weak point then presumably they will wear out in another couple of years, unless Hotpoint have had the foresight to replace them with better quality material.
