Hi there, I have a Hotpoint Wf541G washing machine. I have an issue with the screw off drain /filter plug jammed with coins and hairclips and kept on getting the reduce crease light flashing along with a rapid flashing on/off button. Anyway, got this sorted by removing the assembly of the drain unit and clearing blockage. However when I turned machine on again a new problem occurred.
No I have the mini load flashing with the rapid flashing on/off button as well a the sound of a constant drain. I have done a few searches and common message seems to be pcb.
However, I tried switching the machine off and on at the mains then putting it straight onto a wash. Hey presto it worked. Load washed.
Thing is, as soon as the wash was finished flashing lights again. Mini load and on/off????
I'm totally confused and would appreciate any help or advice.
David
David
