Bear in mind it was described as "huge" by a sparky, who will be thinking about the load on an electrical circuit rather than the heat output, and from an electrical load point of view that is quite a lot to be drawing to one source. Probably the equivalent of a boiler needing a 35mm gas supply or something, you'd need a new supply brought in from the road.
