I had a moling company replace my mains supply pipe recently, because the existing copper pipe was leaking around the floor where it was coming up from. They used a core drill to drill down through the floor/wall to the outside underground, where the new pipe ran to the mains supply. The problem is the hole they drilled was about 10->20 mm from an existing copper pipe which also goes under the kitchen floor and supplies water to the rest of the house. This copper pipe is now leaking (noticed a few days after the new supply pipe was fitted), I think the drilling might have disturbed it and caused this.
Is this a mistake of the moling company to drill so close to an existing pipe? Or just my fault for having bad plumbing?
Here is a photo: https://1drv.ms/u/s!AmGtZYDBXzj8iLwdqx8KlFNyfRmd4Q?e=a1cg4I (don't be mislead by the drip seen from the supply pipe joint, this pipe is getting sprayed by the leak coming from the floor)
What's the best solution here? I'm thinking to have the water to the rest of house rerouted to run along the walls behind the kitchen cabinets, instead of under floor - which just seems to be asking for trouble.
