How come whenever i post a NEW topic it doesn't show up as a new topic yet people see it and respond to it?
I have posted topics on
Gloworm swiftflow 80
Gloworm compact 80
Vokera 80 and
Ideal mini
but the only one i can see is the Ideal mini one?
Am i not clicking on the right icon or something?
Moderator's Note:I can see all of these (below). Is one of them the one you're worried about?
If you click on "Plumbing and Central Heating" can't you see them?
Have you put up any posts with your company name or website in, or any that might be considered advertising, or abusive, or spam?
Mod Rupert
Topic: Gloworm swiftflow 75 problem today
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 9:47 pm Post Subject: Gloworm swiftflow 75 problem today
You see. . . all you really need is a big hammer!
Topic: How come whenever i post a NEW topic it doesn't show?
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 9:44 pm Post Subject: How come whenever i post a NEW topic it doesn't show?
Gloworm compact 80
Vokera 80 and
Ideal m ...
Topic: Halstead Quattro Gold
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 9:39 pm Post Subject: Halstead Quattro Gold
what is the pressure gauge reading? Some boilers won't work at all if there is less than 0.7bar on the gauge.
Topic: Gloworm Swiftflow 80 manual required.
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 9:34 pm Post Subject: Gloworm Swiftflow 80 manual required.
I don't suppose anyone has one that they could email to me please?
I must have over 500 manuals in pdf format that i bought off of ebay but this one isn't on either of the 2 cds and its one i need.
Topic: Gloworm Compact 80e problem
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 8:58 pm Post Subject: Gloworm Compact 80e problem
Do you live in wakefield strachan? I may know you if i saw you. I was trained by Jeff White and was mainly with Victor whilst at the Gas Care Centre.
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 8:55 pm Post Subject: Gloworm Compact 80e problem
i did email you - this morning i think before i went to work. when i got there i was told to get a fan and replace it which i did and as mentioned, it still isn't working. Water is inside the boiler n ...
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 8:33 pm Post Subject: Gloworm Compact 80e problem
Jezzy, WRT the Vokera, why do you think the fan is faulty? Have you taken voltage readings? Have you looked at the wiring diagram and concluded correctly that the fan indeed is defective?
mainly bec ...
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 7:54 pm Post Subject: Gloworm swiftflow 75 problem today
Sorted now. I thought it was the valve because i had stripped it all down and blasted the pilot injector with air. I was fitting meters a month ago and last night i thought to myself that it might be ...
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 6:41 am Post Subject: Gloworm Compact 80e problem
I'm ACS qualified and using the companies corgi 175504. I can set burner pressures but you can't set it if the pilot won't stay lit. Still learning though - i think i always will be. Every appliance i ...
Jezzy
Forum: Plumbing and Central Heating Posted: Thu Nov 30, 2006 6:35 am Post Subject: Gloworm swiftflow 75 problem today
took the nuts off the bottom of the pilot injector and TC and took the whole burner out and blew down it with dust air and i then took the weep tube out of the gas valve and blew down that also from b ...
Jezzy
Forum: Plumbing and Central Heating Posted: Wed Nov 29, 2006 10:18 pm Post Subject: Gloworm swiftflow 75 problem today
Here's todays problem for you all. pilot won't light high enough to even touch the TC and slowly diminishes whilst your still holding the knob in to lower than the level of the pronged thingy where th ...
Jezzy
Forum: Plumbing and Central Heating Posted: Wed Nov 29, 2006 6:59 am Post Subject: Gloworm Compact 80e problem
Be aware these boilers use an unusual gas valve - check the max and min burner pressure on both DHW and heating - they often go off spec (higher).
How can i check the min and max settings when its fi ...
Jezzy
Forum: Plumbing and Central Heating Posted: Wed Nov 29, 2006 6:51 am Post Subject: Gloworm Compact 80e problem
Thanks for replies, they will give me something to go at.
Got a running 80sp fan in the garage you can have for nowt if you`re near wakefield? Thanks for that Strachan, i'm at Agbrigg - but not one o ...
Jezzy
Forum: Plumbing and Central Heating Posted: Tue Nov 28, 2006 11:20 pm Post Subject: Gloworm Compact 80e problem
Anyway, on another thread, i also went to a vokera 80sp today that won't fire up at all. When i took the covers off there was everything in there but the actual bird (it was like a nest). After i clea ...
Jezzy
Forum: Plumbing and Central Heating Posted: Tue Nov 28, 2006 11:11 pm Post Subject: Gloworm Compact 80e problem
Yes i know where the DHW heat exchanger is and what it looks like and does but with you saying it was the first to get crudded up it confused me as i thought that the main heat exchanger would crud up ...
Gloworm compact 80
Vokera 80 and
Ideal mini
Mod Rupert
Jezzy
Jezzy
Gloworm compact 80
Vokera 80 and
Ideal m ...
Jezzy
Jezzy
Jezzy
Jezzy
Jezzy
mainly bec ...
Jezzy
Jezzy
Jezzy
Jezzy
Jezzy
Jezzy
Jezzy
Jezzy
