How do I remove my Honeywell ST9100S thermostat dial to replace with Hive receiver
26 Feb 2021
Hi, I'm wanting to replace my Honeywell timer/clock with the Hive single receiver and completely remove the dial thermostat but not sure what to do with the wires from the stat.
Here are the pictures of the setup..
1&3 on thermostat get joined together and insulated and the Earth gets safely terminated and tucked away
1&4 on timeswitch to 1&3 in Hive single channel
L&N to L&N and Earth to Earth thether on the Hive
Thanks ianmcd, will this be okay as a permanent solution then if safely insulated and tucked away?
yes as long as it is safely isolated, ideal way would be to trace the two wires and remove them and insert a link , but sorry cant guide as to where that will be without seeing it
Well the wires run under my stairs then into a wire track in my kitchen, but from there ‍♂️
Thanks for the advice anyway.
very common to do it the first way, if the stat is fitted onto a pattress box just buy a blanking plate
