Morning all
I have a garage 6m wide, 5m deep newly done in need of light, how many LEDS battens will I need to be able to see well and work on my classic car.
would 6 LED Battens be fine?
I looked at these?
https://www.tlc-direct.co.uk/Products/KBBAT5.html
Slimline LED Batten Fitting
230V, 4000k ultra-bright LED batten.
Manufactured from steel with polycarbonate diffuser.
Double insulated, lightweight, versatile and Slimline.
Simple to install via easy wire terminal box on the rear. Alternative to T5/T8 batten.
Ideal for commercial / retail and domestic use, under cabinets, in hallways and kitchens. Integral driver, non-dimmable.
Width: 35mm - Projection: 45mm
I looked at these?
- Length: 1520mm
- Width: 30mm
- Projection: 45mm
- Lumen: 2300
- Colour: Cool White - 4000k
- IP20
- Dimmable: NO
- Warranty: 3 years (replacement)
- Mains: 230v
- Wattage: 25w
- Construction: Steel / Polycarbonate
- Beam Angle: 120°
- S
