Good evening gentlemen,
I need help!!
I have a loft conversion and there is no light switch at the base of the stairs. I have to walk into the middle of a dark room to turn the light on. As you can imagine this isn't ideal. I set about to add a 2 way switch to the system at the base of the stairs after finding instructions on the internet, however when I removed the switch cover I noticed that the light switch is only switched using the live feed. The neutral and earth continue directly onto the light switch without being broken.
Can anyone advise how to wire in a secondary switch for the type of installation so that I can operate the light from either location?
I look forwad to your reply.
Andy
I need help!!
Andy
