Ideal Esprit HE35 problem - CH fine but no DHW
25 Feb 2012
Hi
Ideal Esprit HE35 combi boiler.
CH is fine and working perfectly, no problems with pressure. Boiler is not delivering DHW though.
There may be some DHW coming through at times when the boiler has been burning for a while for the CH, but at times when there's no need for CH, water coming out the hot water taps gets to lukewarm at best for a short time, then back to cold.
To compound the problem, about a three to four weeks ago, the display on the control panel stopped working. After inspection there was dust all over the covering as if small amounts of water had leaked into the boiler from somewhere and dried in.
Cleaned everything and made sure there was no obvious leak, but took no further action, as at that time, there were no other problems with the boiler.
Lack of display on the control panel obviously means I can't get a fault code from the boiler, if indeed there is one.
Any idea why no DHW? Diverter valve problem?
Could the DHW problem be a symptom of the problems with the control panel?
Any help is much appreciated.
