Ideal HE30 leaking from DHW inlet/outlet pipe - How to fix
9 Oct 2011
Tyne and Wear
Hi all I have a Ideal HE30 boiler that has sprung a leak from the DHW inlet/outlet pipe and I would like to know how to fix as it looks like the pipe fits into the back of the diverter valve manifold by way of a clip ?
Any advice would be greatly appreciated .
Kind regards
Mark
Set of hydroblock o rings 15 mm if it's just the hot and cold shut off mains disconnect pipe from jig, 15 mm fitting with fibre washers. Turn pipes to the side and remove clips and pull out. Put on new o rings with plenty of silicon grease then refit. 20 min job
