Indesit Dishwasher fault codes - can anyone help diagnose please?
20 Oct 2025
Hi, I have an Indesit DIS04 dishwasher and I am unable to complete a cycle. The machine attempts one but I get a constant beeping after around 5 minutes. Errors light are (from left to right) power (flashing), eco (flashing), pots and plates (off), no plates (flashing), pots (off).
Is anyone able to diagnose which fault code this indicates please as I’ve been conflicting advice online. Many thanks.
Thanks but that seems to have contradictory info too. If I select the lights on the flashing led section it says…
F13 - Dryer temperature sensing fault (washer dryers only)
Obviously mine is a dishwasher.
If I go through all the errors above this I’ve found one that matches, F11…
LED 6: ON
• LED 7: ON
• LED 8: OFF
• LED 9: ON
But why the difference?
I am not an expert on dishwashers and Asshurs may see your post and give better advice, but a google search throws this up
An F11 error on an Indesit dishwasher indicates a pump failure, meaning the dishwasher is having trouble draining or circulating water. The most common causes are a clogged or faulty drain pump, blockages in the drain hose or filter, or a motor-related issue. To troubleshoot, first check and clean the filter and drain hose for blockages. If that doesn't work, the pump motor may need professional inspection and possibly replacement.
Thanks. It would be great if it’s the pump as I’m confident to do that myself but I’m not wholly convinced it’s telling me it’s F11. I’m not sure if the power flashing is to be taken into account with the led numbering (ie led 6) and it may be a case of it being a completely different error. Thanks again.
I don't know if this relevant or not... A few years ago, my mum's Miele washing stopped working. The pump would spin but nothing else happened.
Icky, but I blew into the waste pipe and could see loads of gunge go in to the drum. I then got her to do the hottest wash and recommended that she does a max temperature wash once a month or so.
