Indesit wd12x stuck on drain setting
cob
22 Nov 2004
Program was advanced from the fabric softner setting to the next setting, which is the finishing point for the cycle when the non-crease button is pressed, the manual says that this is to be used with programs 5, 6, 7, 9 and 10.
The machine drained successfuly and after that the dial continued to turn... A reset was attempted but now the dial continues to turn stopping and sticking on the rinse setting of programs 1, 2, 3 and 4.
I have checked the pump filter and it's clear... The water drained completely so I guess the drainage pipe is clear...
Any ideas...? Is there a specific button combination to get the original cycle to complete...?
There are no flashes as the dial rotates, does this suggest that there isn't an actual fault...?
Any and all info greatly appreciated...
Kind Regards,
Cob.
