- Joined
- 10 Jul 2013
- Messages
- 1
- Reaction score
- 0
- Country
Hi i have this problem, i tried to replace the c17 capacitor but when i removed the pcb i forgot to do a photo of the connection.....after all i didn't find the cap and so i ordered it by ebay. So i forgot everyrhing about connection....and i did a big mistake...........i put the pump connector into the pcb ( just side to second connector of main power). Everything was goign well the washing machine was workink but when the time of take out water ....led 2&4. So i checked again and i found my mistake...but it was too late. in the main power connector there was a damage and the upper side was not in continuity with the lower side. No other component was apparentely damaged....so i tried again.....wel the machine started to fill...then to drain water and then gives to me 2& door lock red led flashing quickly. And above all i can't put it off...i push the power the led goes off.....but the machine goes on in his work...and it doesn't open the door until i unplug the power cord. Please help me....i know that i could simply buy a new pcb but i would like to repair my pcb....i can send you photo is you need. my pcb is a mark 8 (what components are that big with square ones??) thank tou
edit i tried again and the washing mashine is working...the problem is that the drain pump starts to work immediately.....so the pressure switch that is also working fine gives me the error 2 stuck at empty! could it a relè?
