Installing a vented water cylinder
5 Jul 2009
Kent
Can anyone recommend some good reading matter re fitting a vented water cylinder. I am a tradesperson but need a bit of advice to fit this in my home
Due to building regulations you need to be suitably qualified . Try your local college, normally a one day course for 'tradesmen'
what do you want to know there pretty straight forward,if indirect(heating coil) youll have to drain the heating system as well.just use plenty of ptfe on fittings.if you have a gate valve and is stiff, id personally drain the system down then replace with full bore lever valve.
