installing unvented hot water cylinder
4 Apr 2010
Humberside
If installing a unvented hot water cylinder how would u pipe it up if the cold feed entered the cylinder cupboard at floor height as the composition valve expansion valve and pressure relive need piping in. whic you have the room to do if the cold feed enters from the top of the room
If you need to ask questions like that you're clearly not competent to install it. Installation of an unvented cylinder is notifiable work and you need to be properly qualified to do it, it's not a DIY job
as above you need to hold the G3 cert to install an unvented cylinder & as you clearly don't i wouldn't expect any help on here on how to install it.
Please dont attempt this yourself they are extremely volatile if not installed properly
