Joining 8mm Microbore to 10mm plastic CH pipe
16 Nov 2006
HI
I need to joint some 8mm microbore copper to 10mm plastic pipe. Can you recommend a reducer to do this if one actually exists thanks you
Solder a short piece of 10mm copper to the 8mm (they are a snug fit), then use any connector you choose, to join the two bits of 10mm together.
Thank you for reply I was hoping that a compression fitting would be available. I was looking at Screw Fix and this code seems to be the ticket 55913 but was hoping this would be suitable for plastic on the 10mm side as that what pipe I have to hand. You thoughts are welcomed thank you
