What I've decided to do is acro prop the bedroom ceiling/floor in loft up straight to take out the sag in the 4x2" joists and put some steel straps from each joist to the pearling to keep it there. Then I’m going to put some new plained red wood 4x3” 13 feet long from the main bearing wall to wall plate at 90 degrees to them and fix a coach screw down through the new to the old joist on every joist to tie them all together. Its only going to be used for storage.
My question.
What size coach screws to use to go through the new and into the old joist far enough to give good grip?
My question.
