Hi - new here and after some help!
Had poor water pressure for showers etc so upgraded the house to a sealed system. Problem is that the pressure is fine for about 10-20secs in the shower bath etc then drops right back. After switching off for a while the same thing happens again if you re-try - great for a few moments then poor again.
I have noticed that the pressure is the expansion tank drops right off. If I charge it to 3 bar (3.5 on placard) it holds until I turn on the taps and I can watch it drop as the flow drops off. When the taps are off it doesn't re-pressurise back to 3 bar (or seem to go up at all!).
The system has been like this since the start. We have a water softener with a PRV upstream of the system and the sytem itself has a PRV too. Both rated to 3 bar I think (mains is 6bar). Am I correct in thinking that they shouldn't cause too many probs (although the second one is redundant - but it also contains the strainer).
Did bypass the water softener itself while trouble shooting (though not the associated PRV) and prob still there.
I have disconnected the expansion tank and pumped it up while disconnected, so it looks like the membrane is still intact.
I have also cleaned the strainer (which I had hoped would solve the prob - but no).
Can anyone give me any pointers as to why the flow rate might be dropping off.
