I have to prepare a surface to sit on top of a dexion frame to take a Lathe which weighs aroung 300lbs and has two projecting feet as fixing points. In general wood of any kind is frowned upon for supporting a lathe owing to natural movement with changes in humidity and temperature thus destroying the accuracy of a precise levelling. Will MDF of approx 25mm thick and 1400mm x 650mm area react in the same way as timber, it would be sealed on all surfaces to prevent any ingress of oil but this would not be to any great extent.
Any advice appreciated
Derek
Derek
