Megaflow hot water Cylinder DD210
8 Nov 2009
Manchester
I have lost pressure in my hot water throughout my flat. I've tried to reinstall the air gap but this had no effect.
Mains pressure is fine. I've been advised it may be a blocked strainer. If it is a blocked strainer is this something I can do myself? I presume I'll have to drain the system. Is it something somebody can easily talk me through?
Cheers in advance
Tommy
You'd probably be best to get someone who works on these to do it, prv cartridge needs removing to do this and they're quite often seized. If it's bad you might end up having to change the prv cartridge and housing altogether.
