Hi
We've recently had a new combi boiler fitted to an extended two bathroom house four bed house.
The house is heated using electric underfloor CH but the DHW services the two bathrooms, downstairs wc, kitchen and three towel rails.
The boiler is a Viessmann 100-W 35kW with a flow rate of 12.3l/min.
The problem is when two baths are in use the flow rate is halved to approx. 6l/min which is not acceptable.
The DHW system was a contractor designed item and they are insisting together with Viessmann that the boiler is sufficient for the property.
Are there minimum flow rate requirements or codes of practice that I can reference to prove the system installed in not adequate or is it a subjective issue?
Thanks.
Thanks.
